alekarasma
Newbie level 2
Hello Everyone i m interfacing pic18f458 with mcp2551....but it is not giving me the required output
this is my code for transmitter side
please help me....
thank you
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 void main() { InitECAN(); } void InitECAN(void) { // Enter CAN module into config mode CANCON = 0x80; //REQOP<2:0>=100 while(!(CANSTATbits.OPMODE2==1)); BRGCON1 = 0x01; BRGCON2 = 0x90; BRGCON3 = 0x02; // Enter CAN module into normal mode CANCON = 0x00; while(!(CANSTATbits.OPMODE2==0)); TXB1CON =0x03; TXB1SIDH=0x7E; TXB1SIDL=0x00; TXB1DLC =0x01; TXB1D0 ='A'; TXB1CONbits.TXREQ = 1; //Set the buffer to transmit } and this is the code for receiver side void main() { InitECAN(); } void InitECAN(void) { // Enter CAN module into config mode CANCON = 0x80; //REQOP<2:0>=100 while(!(CANSTATbits.OPMODE2==1)); BRGCON1 = 0x01; BRGCON2 = 0x90; BRGCON3 = 0x02; RXM0SIDH=0xFF; RXM0SIDL=0xFF; // Set to all ‘1’s so filter must match every bit RXF0SIDH=0xFF; RXF0SIDL=0xFF; RXF1SIDH=0xFF; RXF1SIDL=0xFF; RXM1SIDH=0x7E; // RXM1SIDL=0x00; RXF2SIDH=0x7E; //Filter 2 matches 0x3f0 RXF2SIDL=0x00; // Enter CAN module into normal mode CANCON = 0x00; while(!(CANSTATbits.OPMODE2==0)); while(!RXB1CONbits.RXFUL); //CheckRXB1 data=RXB1D0; SendByteSerially(data); }
thank you
