pic18f458 interfacing with mcp2551-problem
alekarasma
Newbie level 2
Newbie level 2
Hello Everyone i m interfacing pic18f458 with mcp2551....but it is not giving me the required output
this is my code for transmitter side
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
void main()
InitECAN();
void InitECAN(void)
    // Enter CAN module into config mode
    CANCON = 0x80;    //REQOP<2:0>=100
    while(!(CANSTATbits.OPMODE2==1));
        BRGCON1 = 0x01;
        BRGCON2 = 0x90;
        BRGCON3 = 0x02;
    // Enter CAN module into normal mode
    CANCON = 0x00;
    while(!(CANSTATbits.OPMODE2==0));
        TXB1CON =0x03;
        TXB1SIDH=0x7E;
        TXB1SIDL=0x00;
        TXB1DLC =0x01;
        TXB1D0  ='A';
        TXB1CONbits.TXREQ = 1; //Set the buffer to transmit
and this is the code for receiver side
void main()
InitECAN();
void InitECAN(void)
        BRGCON1 = 0x01;
        BRGCON2 = 0x90;
        BRGCON3 = 0x02;
        RXM0SIDH=0xFF;
        RXM0SIDL=0xFF;  // Set to all ‘1’s so filter must match every bit
        RXF0SIDH=0xFF;
        RXF0SIDL=0xFF;
        RXF1SIDH=0xFF;
        RXF1SIDL=0xFF;
        RXM1SIDH=0x7E;  //
        RXM1SIDL=0x00;
        RXF2SIDH=0x7E;  //Filter 2 matches 0x3f0
        RXF2SIDL=0x00;
    CANCON = 0x00;
        while(!RXB1CONbits.RXFUL); //CheckRXB1
                data=RXB1D0;
               SendByteSerially(data);
please help me....
thank you
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
void main()
InitECAN();
void InitECAN(void)
        BRGCON1 = 0x01;
        BRGCON2 = 0x90;
        BRGCON3 = 0x02;
    CANCON = 0x00;
        TXB1CON =0x03;
        TXB1SIDH=0x7E;
        TXB1SIDL=0x00;
        TXB1DLC =0x01;
        TXB1D0  ='A';
void main()
InitECAN();
void InitECAN(void)
        BRGCON1 = 0x01;
        BRGCON2 = 0x90;
        BRGCON3 = 0x02;
        RXM0SIDH=0xFF;
        RXF0SIDH=0xFF;
        RXF0SIDL=0xFF;
        RXF1SIDH=0xFF;
        RXF1SIDL=0xFF;
        RXM1SIDH=0x7E;  //
        RXM1SIDL=0x00;
        RXF2SIDL=0x00;
    CANCON = 0x00;
                data=RXB1D0;
please help me....
thank you
I FORGOT TO TELL...
i m using pic18f458 with 4mhz crystal and 125kbps speed for CAN
