[SOLVED] PIC16f886 adc checking problem
ragav4456
Full Member level 4
Full Member level 4
Hi
When i call the ReadADC() function, controller will restarted. what is the reason?
im using Hitech c compiler and MPLABX software.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
#include<htc.h>
#include "adc.h"
__CONFIG(0x20A4);
__CONFIG(0X0700);
unsigned int ReadADC();
unsigned int ReadADC1();
void InitADC ();
unsigned char ucMenu_flag=0;
unsigned int uiHigh_volt=0,uilow_volt=0,uiDR_Amps=0,uiON_Time=0;
void main()
    unsigned int value, ivalue=0,Display=0;
    TRISA=0x03;
    PORTA=0x00;
    TRISB=0x00;
    PORTB=0x00;
    TRISC=0x01;
    PORTC=0x00;
    ANSEL = 0x03;       /* AN0,AN1 as analog pins */
    ANSELH = 0x00;
    OSCCON = 0b01101101;    /*Device runing External Osc*/
    OSCTUNE = 0x00;
     /* Initialize the ADC */
    InitADC(0);
    GIE=1;
    PEIE=1;
    while(1)
        for(value=0;value<60000;value++);  //Delay
        ivalue = ReadADC();
        for(value=0;value<10000;value++);
        Display = ReadADC1();
        Lcd_Decimal(2,13,3,Display);
        for(value=0;value<20000;value++);
      unsigned int ADC_VALUE=0;
//            ADCON1=0b10000000;
        ADCON0=0x43;
        ADIE        = 1;                                                    /* Masking the interrupt */
        ADIF        = 0;            /* Resetting the ADC interupt bit */
        ADRESL  = 0;            /* Resetting the ADRES value register */
        ADRESH  = 0;
        while(!ADIF);       /* Wait for conversion complete */
        ADC_VALUE = (ADRESH*256)+ADRESL;
    return (ADC_VALUE);     /* Return the value of the ADC process */
      unsigned int ADC1_VALUE=0;
        ADCON0=0x43;
        ADRESH  = 0;
        ADC1_VALUE = (ADRESH*256)+ADRESL;
    return (ADC1_VALUE);     /* Return the value of the ADC process */
void InitADC ()
        ADCON1=0b10000000;
I am not using PIC for some time ago so I do not remember it, but do you check the watchdog?
Thanks.
Check Configuration bits properly.Your clock mode is different than your code .You mentioned Internal Osc in Configuration bits and OSCCON = 0b01101101; /*Device runing External Osc*/ in your code
