PIC16F877A How to enable PORT RB1, RB2, RB3, RB4
sajay
Dear Guys,
I got below code on other forum, my question is how to enable PORTB RB1, RB2, RB3, RB4, below code only enable for PORTB RB0 (if (INTCON.INTF) ).
I mean is when RB1 toggle then PORTC & PORTD ON, one more toggle PORTC & PORTD OFF.
int cnt = 127;
void main() {
TRISB = 0xFF;
TRISC = 0X00;
PORTC = 0x00;
TRISD=0x00;
PORTD=0x40;
ADCON1 = 0x7F;          // all pins digital
0xD0;          // gie i int enabled
OPTION_REG = 0x00;
PWM1_Init(5000);         // pwm freq = 5000hz
PWM1_Set_Duty(cnt);
PWM1_Start();
while (1)
void interrupt (void)
if (INTCON.INTF)
  //motor changes direction on each interrupt:
  PORTD.f7=~PORTD.f7;             // D.f7=1 (motor turns clockwise);
  PORTD.f0=~PORTD.f0;             // LED on D.f1 changes state on each interrupt
  INTCON.INTF = 0;                // reset int flag
if (INTCON.INTF)
  PORTD.f6=~PORTD.f6;             // D.f7=1 (motor turns clockwise);
  PORTD.f1=~PORTD.f1;             // LED on D.f1 changes state on each interrupt
use TRISB to change INPUT/OUTPUT = portB direction.
use PORTB to set/clear (high/low, 1/0) PORT B bits.
both are 8 bit registers for 8 bits = 8 data lines of port B.
Read datasheet on this.
Klaus
Because of an example I'm assuming you try to write code in MikroC
If you want to define PORTB pins RB1, RB2, RB3, RB4 as outputs write this:
void main()
  while(1) {
    //define RB1, RB2, RB3, RB4 as outputs
    TRISB.B1 = 0;
    TRISB.B2 = 0;
    TRISB.B3 = 0;
    TRISB.B4 = 0;
    //Turn on Output:
    PORTB.B1 = 1;
    PORTB.B2 = 1;
    PORTB.B3 = 1;
    PORTB.B4 = 1;
    delay_ms(1000);  //paus for 1sec
   //Turn off Output:
    PORTB.B1 = 0;
    PORTB.B2 = 0;
    PORTB.B3 = 0;
    PORTB.B4 = 0;
If you want to define PORTB pins RB1, RB2, RB3, RB4 as inputs write this:
void main()
  while(1) {
    //define RB1, RB2, RB3, RB4 as inputs
    TRISB.B1 = 1;
    TRISB.B2 = 1;
    TRISB.B3 = 1;
    TRISB.B4 = 1;
    //define RB0 as output
    TRISB.B0 = 0;
   //Turn on Output RB0 if one of inputs RB1, RB2, RB3, RB4 = 1;
    if(PORTB.B1 == 1) {
       PORTB.B0 = 1;
    else if (PORTB.B2 == 1) {
       PORTB.B0 = 1;
    else if (PORTB.B3 == 1) {
       PORTB.B0 = 1;
    else if (PORTB.B4 == 1) {
       PORTB.B0 = 1;
    else {
       PORTB.B0 = 0;  //Turn off RB0 if non of RB1, RB2, RB3, RB4  are pressed
