pavelustinov
Newbie level 3
Hello everybody!
Can anyone help me to solve the problem?
I try to print a word on a LCD.
Program compiles successfully, but Proteus doesn't show anything.
Proteus just blink by the lights near LCD.
Proteus scheme listed below.
I think, it just connection problem.
main.h
main.c
flex_lcd.c
main.h
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 #include <16F877A.h> #device adc=8 #FUSES NOWDT //No Watch Dog Timer #FUSES RC //Resistor/Capacitor Osc with CLKOUT #FUSES NOPUT //No Power Up Timer #FUSES NOPROTECT //Code not protected from reading #FUSES NODEBUG //No Debug mode for ICD #FUSES BROWNOUT //Reset when brownout detected #FUSES NOLVP //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O #FUSES NOCPD //No EE protection #FUSES NOWRT //Program memory not write protected #use delay(clock=20000000)
main.c
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 #include "main.h" #include <flex_lcd.c> void main() { lcd_init(); setup_adc_ports(NO_ANALOGS); setup_adc(ADC_OFF); setup_psp(PSP_DISABLED); setup_spi(SPI_SS_DISABLED); setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1); setup_timer_1(T1_DISABLED); setup_timer_2(T2_DISABLED,0,1); setup_comparator(NC_NC_NC_NC); setup_vref(FALSE); while(1) { lcd_putc("\fReady...\n"); delay_ms(700); } }
flex_lcd.c
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 // flex_lcd.c // These pins are for the Microchip PicDem2-Plus board, // which is what I used to test the driver. Change these // pins to fit your own board. #define LCD_DB4 PIN_C0 #define LCD_DB5 PIN_C1 #define LCD_DB6 PIN_C2 #define LCD_DB7 PIN_C3 #define LCD_E PIN_A1 #define LCD_RS PIN_A0 #define LCD_RW PIN_A2 // If you only want a 6-pin interface to your LCD, then // connect the R/W pin on the LCD to ground, and comment // out the following line. // #define USE_LCD_RW 1 //======================================== #define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines #define lcd_line_two 0x40 // LCD RAM address for the 2nd line int8 const LCD_INIT_STRING[4] = { 0x20 | (lcd_type << 2), // Func set: 4-bit, 2 lines, 5x8 dots 0xc, // Display on 1, // Clear display 6 // Increment cursor }; //------------------------------------- void lcd_send_nibble(int8 nibble) { // Note: !! converts an integer expression // to a boolean (1 or 0). output_bit(LCD_DB4, !!(nibble & 1)); output_bit(LCD_DB5, !!(nibble & 2)); output_bit(LCD_DB6, !!(nibble & 4)); output_bit(LCD_DB7, !!(nibble & 8)); delay_cycles(1); output_high(LCD_E); delay_us(2); output_low(LCD_E); } //----------------------------------- // This sub-routine is only called by lcd_read_byte(). // It's not a stand-alone routine. For example, the // R/W signal is set high by lcd_read_byte() before // this routine is called. #ifdef USE_LCD_RW int8 lcd_read_nibble(void) { int8 retval; // Create bit variables so that we can easily set // individual bits in the retval variable. #bit retval_0 = retval.0 #bit retval_1 = retval.1 #bit retval_2 = retval.2 #bit retval_3 = retval.3 retval = 0; output_high(LCD_E); delay_cycles(1); retval_0 = input(LCD_DB4); retval_1 = input(LCD_DB5); retval_2 = input(LCD_DB6); retval_3 = input(LCD_DB7); output_low(LCD_E); return(retval); } #endif //--------------------------------------- // Read a byte from the LCD and return it. #ifdef USE_LCD_RW int8 lcd_read_byte(void) { int8 low; int8 high; output_high(LCD_RW); delay_cycles(1); high = lcd_read_nibble(); low = lcd_read_nibble(); return( (high<<4) | low); } #endif //---------------------------------------- // Send a byte to the LCD. void lcd_send_byte(int8 address, int8 n) { output_low(LCD_RS); #ifdef USE_LCD_RW while(bit_test(lcd_read_byte(),7)) ; #else delay_us(60); #endif if(address) output_high(LCD_RS); else output_low(LCD_RS); delay_cycles(1); #ifdef USE_LCD_RW output_low(LCD_RW); delay_cycles(1); #endif output_low(LCD_E); lcd_send_nibble(n >> 4); lcd_send_nibble(n & 0xf); } //---------------------------- void lcd_init(void) { int8 i; output_low(LCD_RS); #ifdef USE_LCD_RW output_low(LCD_RW); #endif output_low(LCD_E); delay_ms(15); for(i=0 ;i < 3; i++) { lcd_send_nibble(0x03); delay_ms(5); } lcd_send_nibble(0x02); for(i=0; i < sizeof(LCD_INIT_STRING); i++) { lcd_send_byte(0, LCD_INIT_STRING[i]); // If the R/W signal is not used, then // the busy bit can't be polled. One of // the init commands takes longer than // the hard-coded delay of 60 us, so in // that case, lets just do a 5 ms delay // after all four of them. #ifndef USE_LCD_RW delay_ms(5); #endif } } //---------------------------- void lcd_gotoxy(int8 x, int8 y) { int8 address; if(y != 1) address = lcd_line_two; else address=0; address += x-1; lcd_send_byte(0, 0x80 | address); } //----------------------------- void lcd_putc(char c) { switch(c) { case '\f': lcd_send_byte(0,1); delay_ms(2); break; case '\n': lcd_gotoxy(1,2); break; case '\b': lcd_send_byte(0,0x10); break; default: lcd_send_byte(1,c); break; } } //------------------------------ #ifdef USE_LCD_RW char lcd_getc(int8 x, int8 y) { char value; lcd_gotoxy(x,y); // Wait until busy flag is low. while(bit_test(lcd_read_byte(),7)); output_high(LCD_RS); value = lcd_read_byte(); output_low(lcd_RS); return(value); } #endif
