nagkiller
Full Member level 4
Hello!!!
I need help in CCS compiler (V4.140), the PIC16F76 cannot run lcd in ISIS PROTEUS (V7.10)...
I trying the example created by the Project Wizard.
This is the log
Thanks.
Sorry for bad english.
This is the log
Message Source Time
ISIS Release 7.10.00 (Build 12325) (C) Labcenter Electronics 1990- 2011.
Source code build completed OK.
Compiling design 'C:\Program Files\PICC\Projetos\PIC16F76\Outro\Teste LCD.DSN'.
Netlist compilation completed OK.
Netlist linking completed OK.
Partition analysis completed OK.
Simulating partition [77F7A989]
PROSPICE 7.10.00 (Build 11592) (C) Labcenter Electronics 1993-2011.
Loaded netlist 'C:\Users\xxxxx\AppData\Local\Temp\LISA0013.SDF' for design 'C:\Program Files\PICC\Projetos\PIC16F76\Outro\Teste LCD.DSN'
PIC16 model release 7.10.00 (Build 12500) simulating PIC1676 device. U1
[COFF] Loading PIC COFF file 'Outro.COF'. U1
END Of BOOTING U1
Loaded 356 program words and 0 data bytes. U1
Logic contention(s) detected on net #00003.
Logic contention(s) detected on net #00002.
Logic contention(s) detected on net #00001.
[PIC16 MEMORY] PC=0x015F. Attempt to write unimplemented memory location 0x010D with 0x0C ignored. U1
[PIC16 MEMORY] PC=0x0161. Attempt to write unimplemented memory location 0x010F with 0x00 ignored. U1
[PIC16 MEMORY] PC=0x00F5. Attempt to read unimplemented memory location 0x018C ignored. U1
[PIC16 MEMORY] PC=0x00F5. Attempt to write unimplemented memory location 0x018C with 0x80 ignored. U1
[PIC16 MEMORY] PC=0x00F6. Attempt to read unimplemented memory location 0x018C ignored. U1
[PIC16 MEMORY] PC=0x00F6. Attempt to write unimplemented memory location 0x018C with 0x01 ignored. U1
[PIC16 MEMORY] PC=0x00FA. Attempt to read unimplemented memory location 0x010C ignored. U1
Thanks.
