pic16f676 adc problem no problem with pic16f684
zeroskj1988
hello i am using this code to detect ac voltage in pic16f676.but it is not working properly.but it working properly on 684.please spot error thanks in advance
#include <main.h>
#define mains_ok PIN_C4
#define phase_seq PIN_A2
#rom 0x2100={255,170,0}
int1 voltage_check();
void switch_check();
int16 r_volt,y_volt,b_volt,high_cutoff,low_cutoff;
int8 i,ebfail=1;
void main()
setup_comparator(NC_NC_NC_NC);
setup_adc(ADC_CLOCK_DIV_32);
setup_adc_ports(sAN5|sAN6|sAN4|VSS_VDD);
high_cutoff=read_eeprom(0);
high_cutoff=high_cutoff+10;
low_cutoff=read_eeprom(1);
while(1)
if(voltage_check())
//if(ebfail)
output_high(mains_ok);
//ebfail=0;
else
//if(!ebfail)
//for(i=0;i<15;i++)
//delay_ms(1000);
//if(!voltage_check())
output_low(mains_ok);
//ebfail=1;
int16 adc_volt;
if(!input(phase_seq))
return(0);
set_adc_channel(4);
delay_us(10);
adc_volt=read_adc();
r_volt=(adc_volt*.5635)+1;
set_adc_channel(5);
delay_us(10);
y_volt=(adc_volt*.5635)+1;
set_adc_channel(6);
delay_us(10);
b_volt=(adc_volt*.5635)+1;
if((r_volt<high_cutoff) & (y_volt<high_cutoff) & (b_volt<high_cutoff) &(r_volt>low_cutoff) & (y_volt>low_cutoff) &( b_volt>low_cutoff))
return(1);
else
return(0);
Which compiler is this? I'm guessing Hi-Tech C.
Did you select the device properly in the compiler? Did you select the appropriate configuration bits?
---------- Post added at 02:39 ---------- Previous post was at 02:38 ----------
Make sure you have 16F676 selected in the compiler rather than 16F684.
i am using ccs compiler.program is working some times.but not every time.can u spot any error on program or any special difference in program from 684
If it works all the time for 16F684, then code isn't wrong. There might be a problem in the settings you selected. What configuration settings did you use?
i am using this cofiguration
#include <16F676.h>
#device adc=10
#FUSES NOWDT //No Watch Dog Timer
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOPUT //No Power Up Timer
#FUSES MCLR //Master Clear pin enabled
#FUSES NOBROWNOUT //No brownout reset
#FUSES NOPROTECT //Code not protected from reading
#FUSES NOCPD //No EE protection
#use delay(clock=20000000)//,RESTART_WDT)
