Register Log in
PIC16F628A and 4 bit LCD programming question
Jman 31
Member level 2
Hi Guys,
I am working on the programming for this circuit. I decided to simplify it to the most basic form. Starting with getting the LCD working. I have done plenty with LCD's on the Arduino so I have a good idea of how they work.
I am having trouble getting the programming to work.
Here is the circuit:
and here is the simple program that I am trying to run:
 * Project name:
     Lcd_Test (Simple demonstration of the LCD Library functions)
 * Copyright:
     (c) MikroElektronika, 2005-2008
 * Description:
     This is a simple demonstration of LCD library functions. LCD is first
     initialized, then some text is written at the first row.
 * Test configuration:
     MCU:             PIC16F628A
     Oscillator:      HS, 08.0000 MHz
     Ext. Modules:    LCD 2x16
     SW:              mikroC v8.0
 * NOTES:
     None.
char *text = "mikroElektronika";
void main() {
  Lcd_Config(&PORTB, 5, 6, 0, 4, 3, 2, 1); // Lcd_Init_EP5, see Autocomplete
  LCD_Cmd(LCD_CLEAR);       // Clear display
  LCD_Cmd(LCD_CURSOR_OFF);  // Turn cursor off
  LCD_Out(1,1, text);       // Print text to LCD, 1st row, 1st column
  Delay_ms(1000);
  LCD_Out(2,6,"mikroE");    // Print text to LCD, 2nd row, 6th column
I have compiled it and it compiles fine. I used the default device flags that come with MikroC. I then programmed it with my PICKit2 and it programmed fine.
I am getting a row of white boxes across the top of the LCD which means that the LCD is not initializing. Does anyone have any idea what i could be doing wrong?
Thanks
J
jumper2high
Full Member level 3
Serbia
There may be a function called 'LCD_Init' or something like that...which you may need to call before sending out any commands.
microlab
Full Member level 5
Hi
jumper is right
there' s a line missing and that's Lcd_Init();
and just add a while loop at the last line in the main routine
like the following
void main() {
Lcd_Init(); // newly added
Delay_ms(1000);
while(1){
} // actually you don't need to use the braces
also adjust the contrast of the lcd
just connect the lcd pin15 to Vcc via a 1Kohm resistor
and the most IMPORTANT have you selected the fuse bits in proper way? i could not find any crystal connected to your circuit. the default setting in MicroC is HS that's external crystal. you must set is to INTernal Osc and do the other fuse settings. your system should work fin
regards
ml
Tahmid
Advanced Member level 5
Silicon Valley, California, USA (from Dhaka, Bangl
void main() {
  Delay_ms(1000);
Change this to:
void main() {
  //You can also write LCD_Init()
  //But LCD_Config allows you to set each LCD data and command pin according to your requirement
  Delay_ms(1000);
  while (1); //Endless loop
Hope this helps.
Tahmid.
Jman 31
Member level 2
Thanks guys. Sorry I posted this and then haven't posted back. I have been busy with my son's basketball team.
It was in the fuse settings. When I changed to the internal oscillator it took care of the problem!
Ayie29
Newbie level 6
want to ask the what's ur mean by do other fuse settings? what is mean by fuse setting? isnt at the edit project there? and the oscillator should set to which one? clickout on RA6 or I/O on RA6?
vinalice
Newbie level 1
Lcd_Config(&PORTB, 5, 6, 0, 4, 3, 2, 1); // Lcd_Init_EP5, see Autocomplete <----what does this do? When i insert into my coding,error found.
Toggle Sidebar
