The thing is for some PIC18F, such as PIC18Fxxx0/xxx5, the maximum Vpp is 12.5 V, or the maximum Vpp of PIC18F18Fxx10/xx90 is 12V. Can you use 13V zener in those cases?seadolphine2000 said:Thanks namqn for your help, but I've already used it so many times with my PIC16F84A and it works fine. However, If you mean by "don't have a voltage clamper for Vpp" that the voltage at Vpp may increase, I can use a 13v. zener like the one at VDD.
Thanks again for your help.
For the PIC18F2550 and PIC18F4550, you should not go over the maximum Vpp specified in the Programming Specification.tocal09 said:I use JDM programer version in olimex.com . And I used it to program my 18F252,2550,4550. It worked. My Vpp voltage in programmer is about 13,4V. If you want, you could test with Vpp increasing step by step.
@namnq: you tested many progammer, do you know about my case?
This one could only do LVP (Low-Voltage Programming), with Vpp = Vdd when programming/verifying. If you at sometime need to erase the chip (e.g., for clearing protection bits), then you would need another high voltage programmer (Vpp = Vihh, min = Vdd + 4.0 V, when programing/verifying).seadolphine2000 said:Hi,..
I found this programmer. Please, I need to know if it will work with my PIC18F4450 specifically.
Thanks very much for all your help.
seadolphine2000 said:Hi..
I know it might be a silly question, but it's important for me.
Can anyone tell me if this programmer could work with all PIC types.?
I mean can I use this programmer with PIC18F series?
Try the Inchworm ICD2 programmer on my site. It's far better than most simple programmers and is supported in MPLAB
PS
I'm working on a robot kit with chassis. Uses the 16F886 or 18F2525.
**broken link removed**[/img]
