peacezim
Dear All,
I am facing a problem in testing a very simple code with PIC16F73.
I just want to set the PA0 pin high, so that I can see the LED switched ON.
But unfortunately I cannt see this happening in the hardware.
But at the same time I can see the same code in the MPLAB simulator working fine.
I guess it is a hardware problem. I do not know how can I check if the crystal oscillator is working fine. I do not have a CRO. I am using 4MHz crystal with HS mode.
I even tried changing the Chip once. But cudnt help me .
Can any one propose some ideas to test what is wrong in it?
Can anyone provide a working hex file tested on ur PIC, so that I can check it here too?
