PIC Assembly: How to declare an Array?
neoaspilet11
Full Member level 5
Full Member level 5
Cebu, Philippines
pic assembly array
Guys,
I have a problem in PIC assembly.
1.) Suppose I have variables like ARG00 ARG01, ARG02, ARG03, ...ARGN, how can I declare them as an array elements say ARG(0 to N)?
2.) How to access the nth element of the array say for example ARG(4)?
By the way it should not use indirect addressing mode via INDF and FSR registers.
Is array declaration possible withour using indirect addressing modes?
Thanks for any ideas.
jonw0224
Full Member level 4
Full Member level 4
USA
pic asm array
You can declare and address of ARGARRAY that points to beginning of a bunch of register variables that make up your array, this way:
CBLOCK
         ARGARRAY : 0
         ARG00, ARG01, ARG02, ARG03, ARG04
ENDC
ARGARRAY has the same address as ARG00
Address the register ARG04 OR use indirect addressing this way:
movlw ARGARRAY + D'4'
movwf FSR         ;Now INDF returns ARG04
It depends on what you are doing. Declaring an "array" as I suggest allows you to treat it like an array using conditional compiling without using indirect addressing. For example you can write
local i
i = 0
while i < 5
movf ARGARRAY + i, w   ;move ARG(i) to WREG
i++
endw
When you assemble this will generate the commands
movf ARGARRAY + 0, w  ;ARG00
movf ARGARRAY + 1, w ;ARG01
movf ARGARRAY + 2, w ;ARG02
movf ARGARRAY + 3, w ;ARG03
movf ARGARRAY + 4, w ;ARG04
Hope that answers your question. I'm sure it's not exactly what you want to hear, but that's the best I know how to do these things in PIC assembly.
neoaspilet11
Full Member level 5
Full Member level 5
Cebu, Philippines
pic assembly arrays
Hello Jonw0224,
Thanks,
But I think I will be forced to use INDF and FSR registers because the array is too huge. at least 120 elements and at most 240 elements which occupy several banks of RAM registers. Its pretty tedious because of switching banks in the coding. However I made a code last night to cater 240 elements and it works perfectly fine.
Thanks you and happy new year
jonw0224
Full Member level 4
Full Member level 4
USA
assembly declare array
neoaspilet11
I agree, generally it is easiest to use FSR and INDF registers for handling arrays. I'll admit, this is tricky with several banks and you definitely don't want to use the conditional compile loop I suggested.
Good luck and happy new year to you too
-jonathan
