24f16ka102
Hi!
I'm having a problem with the CN interrupts on the PIC24F16KA102. The interrupt routines work fine in almost any situation except when using SPI. If I enable the SPI module, the CN interrupts don't work anymore. It doesn't matter which pin is used, i've tried all possibilities.
My question is:
- Can I use SPI module and CN interrupts together?
- If yes, what could be the problem with my design? (I'm using simple code copied from the peripheral library documentation examples)
Thanx for your help!
