Pic 18f4550 + enc28j60
bbassem
Newbie level 3
Newbie level 3
Hi, I'm working in web server project using PIC 18f4550 + ENC28j60, I found 2 examples (below) , I tested them to know the working principle of the TCP / IP stack, but it doesn't work, I've looked for a solution from many forums but I didn't found any solution ,can anyone help me please.
(Sorry for my bad english)
View attachment EXamp.rar
Hi there, Microchip already provided the TCP/IP stack for PIC 18F4550 on their website, there're user manual also. please check :)
in the legacy version of Microchip's MLA
there is a sample project for a PIC18F8722 and a ENC28j60 in directory
C:\microchip_solutions_v2013-06-15\TCPIP\Demo App
although it is for a different PIC18 the sample code may help
there is a working example of a PIC 18f4550 + ENC28j60 on youtube
https://www.youtube.com/watch?v=IE0tma-FhD0
Thank you for responding ,I saw the links but unfortunately, they did not help me, my probleme that I can't get an IP address, when I try to simulate the examples ( which i found) in ISIS , a error message appears, the error is related to the NCIS.DLL, I made a screenshot of the error Isis Error.PNG
The workload for the ENC28J60 for the PIC18F family of devices can be quite high, especially at some early stages when the timing can be critical - probably why you are getting that previous error message form the simulator about excessive CPU load as the simulator can't really keep up with a MCU that is working flat out.
I strong;y recommend that you get real hardware and run the MAL TCP/IP code on that - it does work (provided you have the circuit set up correctly).
Susan
