PHY interface of USB 2.0 core
jenardo
Newbie level 6
Egypt
Hi all,
In case of implementing a USB 2.0 core, I wanted to ask about its PHY interface.
1) Is it possible to output D+ and D- directly from the FPGA ?
2) or is some kind of transceiver in between needed to convert high and low voltages to a differential one ?
3) What is an UTMI interface ? and where exactly is it located in a design ?
Thanks
alzomor
Advanced Member level 2
Cairo
Re: USB 2.0 core
You need 1st to check USB2.0 specifications @
https://www.usb.org/developers
If you could meet the Phy specs @ D+ & D- using your FPGA , so you can use it for direct connection , but I don't think it's possible.
all designs use a PHY interface layer which is UTMI or ULPI.
Regarding the UTMI you can think of ULPI also which is simpler.
UTMI is USB 2.0 transceiver macrocell Interface.
and ULPI is a low Low PIN Interface version of UTMI.
Salam
Hossam Alzomor
www(dot)i-g(dot)org
    V
verma.ind
Junior Member level 2
Re: USB 2.0 core
For what purpose we will use chirp counter in USB2.0 core? Can any body help me?
Thanks
gck
Full Member level 3
Re: USB 2.0 core
making D+ and D- sonnection by FPGA is not possible, for that i.e PHY layer chips are avilable u need to interface ur core with that.
qasmi
Member level 3
USB 2.0 core
Is there any controller IC that interfaces with the PHY Layer Chip or USB Transceiver, instead of implementing the core in FPGA?
