photodiode detector circuit with amplifier
sangkeetha
hi,
I'm going to design a simple fibre optic vibration sensor. This is how the system works:
LED illuminates the optical fibre and the light ray propagates inside the fibre and the change of transmission properties of the light propagating in the fibre will be detected by a photodiode detector.
I need the design of the photodiode detector with amplifier circuit and LED emitter circuit, with model spec.
Thanx.
photodiode amplifier
hi
use "photodiode amplifier; opamp solution"
this book exist in froum download center.
good lock
photodiode detector circuits
hello
forthis i think first u have to design the photo diode amplifier and calibrate its output then refer it with the original signal. for light emitting please secribe more about your led specification
photodiode detector
If you have no reference phase how do you propose to detect movements?
Also. I have designed a quite similar method.
