powersys
Advanced Member level 1
Hello,
I copied the following paragraph of text from:
https://www.allaboutcircuits.com/vol_2/chpt_10/7.html
Kindly advise the following:
[Q1] In practice, do you think the waveforms of a 3-phase system (any 3-phase system, not restricted to power generation) might have different frequency? Please provide a practical example.
[Q2] If the waveforms in a 3-phase system have slightly different frequency, do you think the phase shift between any two of them will be constant? If the phase shift is expressed in term of 'angle', will it be constant? If the phase shift is expressed in term of 'time', will it be constant?
Thank you very much
For the more mathematically inclined, this principle may be expressed symbolically. Suppose that A represents one waveform and B another, both at the same frequency, but shifted 120o from each other in terms of phase. Let's call the 3rd harmonic of each waveform A' and B', respectively. The phase shift between A' and B' is not 120o (that is the phase shift between A and B), but 3 times that, because the A' and B' waveforms alternate three times as fast as A and B. The shift between waveforms is only accurately expressed in terms of phase angle when the same angular velocity is assumed. When relating waveforms of different frequency, the most accurate way to represent phase shift is in terms of time; and the time-shift between A' and B' is equivalent to 120o at a frequency three times lower, or 360o at the frequency of A' and B'.
Thank you very much
