yo8tot
Newbie level 6
What is the full scale input voltage of PCM4202 ADC? Acording to datasheet this is 6V. However it say also this:
"The analog input
should not swing below analog ground or above the VCC
power supply by more than 300mV."
and then this:
"The full-scale input of the PCM4202 is 6.0VPP
differential, while it is 5.0VPP for the PCM1804. This
is a result of the PCM4202 having an internal +3.0V
voltage reference, and the PCM1804 having an
internal +2.5V voltage reference. "
But the supply voltage is 5V, also in application example. (6V is max. absolute value).
"The analog input
and then this:
