PCB simulation in ADS
lfx0828
Hi all,
Recently, I am trying to do EM simulation of a 2-layer PCB in ads.
Unfortunately, the result is not correct, it seems there is an open-circuit for the non-ground via.
As shown in the attached image, the DC properties on the top layer is correct, but on the bottom layer is wrong.
The project file is also attached.
Any help will be fully appreciated!
  • EM_V1.zip
I took me a while to find the mistake: your look-alike symbol is outdated, and does not match the port definitions (port position) in your EM Model ... which means your schematic port connections are not going to those places that your look-alike shows you!
You need to delete and re-generate the symbol!
Hi volker,
Thanks for your time.
After deleting and re-generating the symbol, I still can't get a good result.
So, could you please send me your project file?
I didn't modify your ADS model.
But you are correct, it is not only the look-alike symbol. Pin/port numbers in layout also do not agree with port numbers shown in EM preview (generated from that exact layout). It seems that EM skips some ports, which means the numbering isn't what you expected.
Looking again, I finally found your mistake: you have changed port ground layer from "implicit" (=ground at infinity) to an explicit drawn ground layer. This means that Momentum will place port ground on that layer, just above/below the port "plus" terminal.
And here comes your mistake: for some ports, there is no metal on that layer that you declared as ground reference layer. Momentum seems to silently (?) discard those ports, which means your port numbering scheme is messed up. See pins 5 and 6 position in layout versus EM preview.
Fix: change the port ground references back to "implicit" for those ports where you have series elements with no ground below. Or second option: place an explicit ground pin at a valid location (on metal) and use drag&drop to assign that pin as minus terminal for your port.portskip.pngport_nognd.png
