sir
which pcb designing software is easy to operate? can anybody send link of site of the same, and possible site of tutorial and installation procedure
I wouldn't say Orcad is easy. I use Eagle, but I wouldn't describe that as easy. Your best bet is to do some searching and download any with working demo versions and see which you get on with quickly.
It again depends upon the design, ie complexity,application etc. for simple kind of designs, like for instance power supply design, Pads Layout is the best.
if the design is bit complex, have more connections then go for Allegro.
While posting your query be very specific, like the complexity , domain etc , to give you more in depth responce.
hi
I reommend you use simple to learn such as Protel, Eagle as
a starter.
There are many free download site available in internet.
P/S:
Learn Protel PCB videos https://www.youtube.com/user/MyAh1n1
You may try dip trace. it will easy to start and there is full featured tool (includes all libraries) available. ( its a free download and valid for 30 days)
Hi all,
self than if you have a "big system" with high component count library (and expensive!) ->> you will to learn, how is a component to create!
Its a mus, & typical job for a layouter_maybe the SW vendors tells it, that "we have a library of i.e. 5000 components, its highest count what you can have"- bla-bla-bla...
In an all days life, you must have every time a newer component, what your library dont give /have for you. Simplest way is to create it self_it is not a problem, only one thing is, that you must have every time your self (or from your CAD) "system", ref des to write on silk and not on some other layer and so on...These "design rules" can you find in the delivered library as easiest source, not a problem every time the same to draw/make...
I wished only to tell: library to create/make is not a absolutee problem & you will/must learn it for comfortable using your system; equal is it a miniatur home worker package or a high end/very expensive system... That is our life ..
K.
