hobbss
Member level 2
Is there a way to designate a shape as filled in PCB Editor (16.3) for the silk screen?
Simple example: the circle marking pin 1 on a SOIC component should be a filled circle. If I add a "filled circle" on the silk screen layer, nothing shows up when I run the silk screen generator and then generate artwork. If I add a shape with a finite linewidth (i.e., 5), the circle is hollow, and I can't seem to move it in the schematic. Meaning, if a circle is placed on a generic SOIC8 footprint, but on a particular board I want to move the dot a few mils, I can't seem to move it without moving the component (in the board file). I suppose I could have decreasing concentric circles with wide width to simulate a filled circle, but it seems like there should be a better way.
More complex example: I have drawn a ESD symbol and saved as a dxf. I then successfully imported it into the design. I can place it on my board, but it is always just the outline -- I can't seem to fill the shape in, even if it is filled in in the dxf file.
