PC to FPGA C++ connection
madalin1990
Full Member level 2
Hi!
I have a program that is supossed to send bits from a file saved in computer to a memory implemented on FPGA. There are two Depp functions used:DeppPutReg is used to specify the start address and DeppPutRegRepeat to copy the data from the file to the memory.
The logic implemented on the FPGA automatically increases the address after a bite is copied at a address. The problem is when i try 2 send 2 bytes the memory address increases by two instead of 16.
My question is what should i modify in the code below to make my HW read the bites correctly:
void DoPutRegs() {
	BYTE	idStartMemAddress;
	char *	szStop;
	long	cb;
	BYTE	rgbLd[cbBlockSize];
	int		cbSend, cbSendTotal, cbSendCheck;
	cb		=  strtol(szCount, &szStop, 10);
	idStartMemAddress = (BYTE) strtol(szAddressStart, &szStop, 10);
	if(!DeppPutReg(hif, HW_REG_MEM_ADDRESS, idStartMemAddress, fFalse)) {
		printf("DeppPutReg failed\n");
		return;
	 fopen_s(&fhin, szFile, "r+b");
	if (fhin == NULL) {
		printf("Cannot open file\n");
		ErrorExit();
// write the file into the data register
cbSendTotal = cb;
	cbSend = 0;
	while (cbSendTotal > 0) {
		if ((cbSendTotal - cbBlockSize) <= 0) {
			cbSend = cbSendTotal;
			cbSendTotal = 0;
		else {
			cbSend = cbBlockSize;
			cbSendTotal -= cbBlockSize;
		cbSendCheck = fread(rgbLd, sizeof(BYTE), cbSend, fhin);
		if (cbSendCheck != cbSend) {
			printf("Cannot read specified number of bytes from file.\n");
			ErrorExit();
		// DEPP API Call: DeppPutRegRepeat
		if(!DeppPutRegRepeat(hif, HW_REG_MEM_DATA, rgbLd, cbSend, fFalse)){
			printf("DeppPutRegRepeat failed.\n");
			ErrorExit();
		printf("Stream to memory complete!\n");
	if( fhin != NULL ) {
		fclose(fhin);
	return;
madalin1990
Full Member level 2
I have managed to find the error. It seems the .txt file save its elements in ASCII code.
My question now is: what type of file saves it's elements binary coded?
