brianguy
Newbie level 3
site:edaboard.com equalizer
Hi everyone. I have a question as follow:
It is well known that the lossy transmission line will induce non-negligible ISI effect on the transmitted digital signal. When a passive equalizer is employed, the ISI effect will be reduced, but inevitable DC-loss will lower the voltage level of signal. For example, the original voltage level is between 0~0.4V. After using the passive equalizer, the voltage level becomes 0~0.2V. If I want to use an "simple" amplifier to enhance the voltage level to the original 0~0.4V, what kind of amplifier circuit should I choose? Can anyone answer this question? Thank you very much
