pass the commands from VC++ program to the command window i
mydreamhouse
skill language
who has the reference of cadence skill language
skill cadence
sklanguser.pdf and skdfref.pdf are the best to start with to learn skill programming. If u want to learn it quick, dont waste time reading it from start to end. Start writing scripts.
I suggest u right a script for Placement. Inputs will be spice file, Pcells library name and then the script should create cells and pcells, sub-blocks in the Top-level library.
skill programming
I started to learn it yesterday, you have given me a very good idea.
Thank you!
cadence skill reference manual
This sounds so complicated. Is this easy to complete ?
cadence skill script
Yes man. It is very Easy. I wrote it long back.
Read the spice open a new cell create pcells. and place it in the top cell (i.e subckt).
This is useful if u are using virtuoso layout editor rather than XL
This is a language used in Cadence tools
skill code cadence
hi
cadence skill language is used in cadence desig enviorment
what ever things u can doing in cadence tool that things u can script it using skill code
regards
analayout
cadence skill programming
You should also get a source link account, so you can ask a cadence rep questions of how to do or why is it not working.
skill language reference
do u have sth in detailed? i need to learn it in depth. thanks.
cadence skill development
Skill development
  • skill_development_1352.pdf
how to learn skill language
skill development function
fundamentals of skill language
and one more
cadence skill pdf
Does anyone have skill training manuel ??
And I want to know the difference between skill and ocean.
Thanks!
cadence skill script help
This is the lab manual for the Skill language from cadence.
Hope it helps
  • skillpro_5_0.lab_6665.pdf
Reactions: maqadar
    V
    maqadar
