I am running a single trace, and wan to run in spiral but the straight trace and then an arc for the same trace since this is a round board. then next loop will be 2 degrees off from the 1st loop for the straight portion. Go through a via, and then do same thing on bottom side and go to a connector. Basically will be working a coil.
I am having difficulty setting the angle and arc for same trace with 5 mil trace and 5mill gap. Anyone know this? There will be 4 quadrant like this, if anyone can help, i can evens end the file and see if it can be done.
