P89V51RD2 problem during reset
SBB
Newbie level 3
Pune
P89V51RD2 problem
I am using P89V51RD2. For ISP there is no problem. When i do ISP my code runs properly, but after RESET (by pressing RESET switch or Power on RESET ) code does not run. Please tell me the solution to come in user code after RESET.
Somphorn
Member level 1
Johore, Malaysia
Re: P89V51RD2 problem
If not already done...
1) connect pull-up resistor 4K7 from ALE to VDD.
2) connect resistor 8K2 from RST to VSS. and connect 10uF electrolytic from RST to VDD.
As far as code is concerned, a reset will always cause the instruction pointer to start execution from location 0000H. If your code runs the first time, then I think it shouldn't be a problem after a reset.
But don't take my word for it. I'm not an expert in this.
pratyathedon
Junior Member level 2
Pune
Do this values of resistor and capacitor matters.
i mean that if i use a 10k resistor instead of 8k2 and 10uf/35v instead of 10uf/16v does it will have any problem
welove8051
Full Member level 6
india
hello
pratyathedon:
the value you choose is of no problem.
what is the code you are running. are you using serial communication. i had some problems when iam using serial communication program in rd2. if thats the case try to give some delay before serial communication in your program.
regards
kj
www.free8051projects.blogspot.com
