TechGuy
Junior Member level 2
Hi Guys,
I'm having some problems with my design, before i finalize it I have decided to do a quick hook up with wires to check if everything is working fine, basically I have and external source of the PWM signal ( just focus only to the first channel for now) it has a resistor divider each of 1K and a 10K in series, then feeded to the MC33926 which is actually a H-Bridge, Brushed DC Motor Driver, but i actually using it as a gate driver for my others mosfets P-Channel from Vishay, each channel should cope with more than 30A. However I feed my PWM signal and have to the output a nice inverted PWM signal ready to drive my Mosfets, and the first test I just tried a small load max 3.3A and the control was working fine and the mosfet was not getting hot at all, but when i switched load and not even too big a 5/6A the mosfet gets very very hot! and I cannot understand why? please find attached my schematic.
Any help would be really appreciated,
thanks
thanks
