Overshoot after current limit!!!
pswatw
Junior Member level 1
hi:
I designed a current mode boost converter!
But there is overshoot in vout when current limit release !
It is not easy to slove this problem use traditional soft start!
How to solve this problem!!??
THANKS!!
PSWATW
leo_o2
China
A good way for it is to design a soft start circuit for reference voltage. If ref voltage starts up very slowly and smoothly, there is no overshoot on output voltage.
Added after 54 seconds:
Torex (a Japanese IC company) has some ICs to suppress overshoot in this way.
pswatw
hi: leo_o2
Thanks for your answer!!
But when the current limit occur, the vref is 1.23v!
the vref will not "starts up"
pswatw
HELP!! TELL ME HOW TO SOLVE THIS PROBLEM, PLEASE
leo_o2
China
If you make the reference voltage starting up very slowly (>1mS), you don't need to do any change for current limit. You can just design a normal current limit (same current limit level for both before start-up and after start-up). For boost, you need to avoid the fast charging for output cap if you can't turn off the PMOS path (for synchronous boost).
