Register Log in
orcad simulation errors - please help with the problem
tufan
Junior Member level 3
orcad simulation problem
HI DEAR FRIENDS
I Have a circuit to simulate in orcad But i could not manage it since it gives some errors .I sent it .I use dc current source ...can you help me?
ME
Topic moved from "Analog Circuit Design" to "PCB Routing & Schematic Layout software & Simulation".
papyaki
Advanced Member level 2
France
Re: orcad simulation problem
Do you have a spice model attached to the transistors. No other component appears in the spice netlist than the two current generators. It is like there is no transistor. So the current generators nodes are flowting.
flatulent
Advanced Member level 5
Middle Earth
The two sets of error messages are related. Your current sources are not really connected to the transistors. What you probably did when drawing the schematic is put the wires close to, but not connected to the nodes of, the transistors.
1. Look at the net list ( the **.net file) and see if this is not true.
2. If this is true, go back to the schematic and remove the wires and draw them again. Make sure that you get the large red disk symbol showing when you end the wires. This indicates that you have made the connection to the next part.
arcaphill
Member level 5
Send the source file!
A
antonio_iea
Looks like you don't have models associated w/ the symbols...
