OrCAD Gerb Tool :Print Out Problem
gurpreet312
Member level 2
Hello Sir,
I am unable to take Print out in A4 Size sheet as per my desired Location.
I am follow below steps:
Options>> Post Process Setting
Tool >> Run Postprocessor
Then go to Gerb Tool
Please guide for that.
Gurpreet Singh
gurpreet312 said:
Hello Sir,
Gurpreet Singh
Hi !
Are you trying to printout your "Gerber Files" ?
In this case, you don't need to load them into "Gerbtool".
In "Layout", choose "Options -> Post Process Settings..."
Then, select the files you want to printout and on "right clic" select "Plot to Print Manager..."
Then, select your usual printer options...
I hope, I could help... ;-)
Regards,
PTK
