Orcad 9.0. - DRC Errors for footprint of the board
kishor jadhav
Member level 1
Pune, Maharashtra, India
drc errors
hi friends,
I am using Orcad 9.0. I was route one board this is my 1st board, i am creating a some footprint & other footprint using orcad layout 9.0. The actual problem i am facing this board when i am checking DRC, lots of error generated not for routing track but for all the footprint of this board even though res , cap 0805 having also DRC Error.
Why this problem is generated for DRC Error? otherwise my board was totally cleared for other testing. so how become overcome this problem? please help I am needed help of you guys.
Thanks In Advance,
Kishor
Kevin
Member level 1
DRC Errors
why didn't check you footprint in library tool?
Vamsi115
Junior Member level 2
Re: DRC Errors
Open the design again, Go to SpreadSheet -> layers a pop up window will open showing all the layer. Disable all other layers which u r not using then come back and click DRC again. This should solve ur problem.
Cheers
VKR
dmd4raj
Member level 4
Re: DRC Errors
To run the DRC check first you have to set the DRC constraints.By default the trace to trace spacing and pad -pad spacing(pitch)and some others will be some values.Go to view or some tabs in the top of tool and select the DRC check tab.In that you select the options you want and run the drc
Regards
Rajan.K
