Operational Amplifier - Design
whirl7wind77
Junior Member level 2
Can anyone tell me,
how to design a high speed, low power ( < 20 uW ) Operational Amplifier ( with supply voltage 1.2 V in 90nm CMOS ) ?
As fast as possible.
You need to choose a proper architecture and to make trade-off between output swing, gain and speed.
Probably the best architecture will be recycled telescopic or folded cascode with degenerated current sources, gain boosting and feedforward compensation.
I knew that. I found in literature that the telescopic one has low power consumption and high speed.
But I could not achieve high speed and 20 uW power consumption. Can you suggest architecture ?
You might need a 2nd stage with good driving capability to get the high speed.
Telescopic in itself with the limited current budget would have limited bandwidth to provide the speed.
I am assuming the by speed you mean the response to switching loads. Try a second stage as a driver which consumes minimum current in DC but is able to drive high current steps.
Telescopic opamp is a good choice for high-speed and low-power consumption. You can find design steps thoroughly in the following book:
Behzad Razavi, Design of Analog CMOS Integrated Circuits, Pages: 299-300
Also I attached the schematic of the circuit.
Hi an_82,
This is the first circuit I tried. My supply voltage is 1.2 V.
This circuit has a problem maintaining bias points. It consumes hundreds of uW power.
So You doing it wrong...
The tail current source determine the power consumption in telescopic cascode. If You set proper W/L ratio for transistors in current mirror You get not more current than You assume.
