[SOLVED] On resistance of nmos switch and transmission gate
Saraadib
Member level 4
I want to measure on resistance of nmos and transmission gate ,I know on resistance is resistance of transistor when transistor is in triode region
I have attached schematic of nmos transistor and transmission gate and plot on resistance of both, however result of them is wrong
Does any body have idea what is wrong with my circuit?
For the 1st two images (7.PNG & 8.PNG) it is not clear (for me) if the nmos is closed or open, because vdc of V6 isn't given.
For the 2nd two images (9.PNG & 10.PNG) both nmos and pmos transistors are heavily "on" (switch closed), yet it is not clear which voltage (if any) is provided by V0. But anyway the low switch resistance of a few tens or hundreds of Ohms should be shown, as the impedance of V0 is zero. I guess the ordinate's scale of 10.PNG is GOhms, isn't it?
in 1 two image(7 and 8 PNG),I sweep vdc of v6 from 0 t0 5V and plot output voltage which voltage at resistance(1G) and subtract it from input voltage which is V6 and divided on Current of nmos
can you please tell me how exactly I have to do for measuring on resistance of switch?
how should I change my circuit to see on resistance of switch
Yes,ordinate's scale of 10.PNG is GOhms
This can't work as here the current is determined by the much higher load resistor of 1 GOhm.
You better put V6 as a fixed voltage source (e.g. 5V) between drain and vdd (i.e. it creates vdd), no load resistor in between, sweep VG between 0 and 5V, and plot vdd divided by the nmos current. Use an ordinate's scale of Ohms, then you should see the nmos' resistance falling from an initially high value below the threshold voltage vth, after exceeding vth it should go down to several hundreds or tens of Ohms when increasing VG up to 5V.
Similar for the 2nd two images 9 & 10.PNG: With a load resistance of 1 GOhm you can't see the much lower transmission gate (TG) resistance. Remove R0 and connect vout to vdd/2. In your configuration the TG is always on (switch closed). Sweep the input voltage V0 from 0 to 5V and plot vdd/2 divided by the current through V0 (which equals the total current through the TG). Here again use an ordinate's scale of Ohms[/U], and you should see the low TG resistance (should look like a Vesuvius: peak near vdd/2 , s. e.g. any 4016|4066 data sheet).
you mean remove 1G resistor and put a dc voltage between drain and source ?you mention vdd ?which vdd you mean?
for nmos I have to remove 1G ohm and then put dc volatge between darin and source and sweep gate volatge from like 0 to 5v and ?where I have to connect to vdd in my circuit?
for nmos you mean like the picture I have attched
Yes!
Or - as you mention above:
put dc voltage between drain and source
- drain is vdd, source is gnd - use these symbols - so the nmos drain is directly connected to vdd.
- And like I explained the changes to it.
I got this figure for transmission gate
is it right?
why I have negative resistance
I got this figure for transmission gate - is it right?
Yes, looks quite good. Use a better resolution (more steps in the sweep command).
It's not really a negative resistance. It's just because current runs in the other direction when vin crosses vout. You could use the absolute value of the current.
And better use (vin - vout) for the abszissa axis to get the correct resistance (I forgot to mention this before). If you followed my suggestion, vout=vdd/2 and so is constant anyway.
ok one more thing if I want to replace a idea switch with tarnsmission gate ,how can i do that?I mean I measure on rsistance of tarnsmission gate if this on reistance is equal to closed switch reistsance ,it means they are same?
I think you can find a transmission gate in the analogLib, or in one of the HDL-Libs (Verilog or VHDL). The latter one should be configurable respective on & off (open & closed) resistance.
