bdl
Newbie level 3
I'm a novice with electronics, I understand most of the basics but I do have what may be dumb questions:
1) In relation to a circuit, how is voltage maintained? My thinking is that if a component in a circuit requires 3V, for example, and I use two "AA" cells to power the circuit, the power source is a constant and all components always have 3V to use. Or is it that each component "leaches off" a bit so that when current reaches a power critical component (an IC of some sort let's say) in the circuit, it's "cheated" in some way? Do I need to calculate the total circuit power requirement to avoid drop-out? If I do this, and add 5V to the circuit, do I simply need to use resistors to limit power to a certain component?
2) What is a practical, real-world application of the Zener diode vs a standard diode? I've used what I would consider a "regular" diode to prevent reverse current flow, how does this differ from what a Zener diode can offer? Some tutorials use them in circuit design to prevent reverse current, is this the correct use of these diodes?
