mijail
I am having some doubts about differential pair routing; I'm hoping someone here can give me some answer / hint / heuristic / pointer about what to do.
The thing is, I have to route a number of differential pairs thru a long, constrained and fragmented space. I have 4 layers to use, the bottom one sporting a ground copper polygon (which does not extend further than the constrained routing area). The signals are expected to be <1 MHz. This is all in the process of reworking an old project, whose choices I am trying to understand/rethink.
So, what of the following would you think is worst, or best?
My bet would be that the last option is the best one. It feels wrong, since I guess I am creating a big capacitor with those long parallel traces, which surely would not be good for a high speed design. But this isn't high speed, so that solution looks like the lesser evil.
I'm also thinking that the ground polygon will possibly be not a very good idea, since it will be affecting the impedance of the tracks in different ways, and being differential pairs anyway a ground plane is less important than the routing itself.
Any thoughts?
- to separate the traces of the differential pairs, even if that means running some of the traces parallel (same or different layer) to other separated differential traces?
- to try to keep traces from differential pairs together and in the same layer, even if that means making them go parallel to other differential pairs in other layers? (That would include things like stacking one trace from a differential pair over one trace from another differential pair in another layer)
- or to keep traces from differential pairs together but stacked, each trace in a different layer? (this would maximize horizontal separation between the various differential pairs)
Any thoughts?
