The manual which you attached explains how can you control the motor at page 2. Construct the schematic given in the manual and put appropriate capacitor value that is specified at the capacitors section of manual with respect to your applied voltage 24 or 48 V and simulate it. Which point you did not understand ?
yes o'course i know that but i have to change motor speed..while i change voltage ,will speed change ?where is the frequency value 50-60hz?i need to change it by using frequency..
yes it is velocity or number of revolution per minute whatever you want to say. If you put the values such as 50 hertz shown in your manual 120*50/10=600 rpm that is shown too at your manual.
