Nmos substrate connection
petros85
Newbie level 3
London
Hi all. I have runt into a DRC error :
MAXIMUM n+ DIFFUSION TO NEAREST p+ PICKUP SPACING(INSIDE P-WELL OR TWELL) IS 20um
I know this is resolved by adding taps or a guard ring around the device. Problem is that I get this error for one device that is quite big. So no matter how close I place the psub contacts I get the error marking the inside middle area of the device (that is further away than 20um from the taps.) There must be a way around this except resizing the nmos. (it is a diff pair in a one-line common centroid and I have tried to make it as square as possible)
Also I am using umc18nm process and I can't automatically create guard ring. It says guard ring template not set. So I manually placed psub contacts around the devices. In my smaller devices it worked nicely. Any advice on how to set the automatic guard ring creation?
why not split that big transistors into smaller ones then make the arrangement ABAB?
Yes that's a solution..I was trying to avoid it since I have already made a floorplan that will have to change now.
It seems too weird if you think about it it means that every device MUST have at least one dimension smaller than 20um. I thought that the 20um rule is from the edge of the diffusion area..not the WHOLE area.
that is the only solution. violating this rule might trigger latch-up because of the potential difference between the 20um region, and beyond it.
