Negative Resistance equation
GGAPBE96
Japan
resistance equation
Many references say negative resistance of colpitts oscillator can describe the following equation.
-R = -gm/ ω^2/C1/C2 (gm :: trans conductance of FET)
However,negative resistance is also proportional to the ratio "C1/C2".
Does anyone tell me how to develop the expression for the exact negative resistance?
Thanks,
colpitts oscillator equation
That is the expression for the negative resistance. Except the equation is:
R= -gm/(ω^2(C1C2))
Wikipedia for Colpitts oscillator shows the derivation of the negative resistance
    GGAPBE96
equation for resistance
R= -gm/(ω^2(C1C2))
Thank you for the comment.
I know the equation,but I believe this expression is not exact.
In fact,negative resistance is the function of C1,C2,and C1/C2,
but the equation means the negative resistance is only inversely proportional to C1,C2.
It does not depend on the ratio C1/C2.
negative resistance oscillators:
The equation must contain the PRODUCT (and not the ratio of both capacitors).
One simple reason: Otherwise the units of the right side of the equation give not "ohms".
    GGAPBE96
math equation negative 35
Yes,I agree with you.The equation itself is correct.
But I think it is not perfect.
I believe there is more accurate expression to describe the negative resistance.
For example,
R = -gm/(ω^2C1C2) + f(C1,C2,C1/C2)
Of cource,the dimension of the additional term is ohm.
negative equation oscillator circuit
the complex impedance that the inductor sees is
Zin= 1/sC1 + 1/sC2 - gm/(ω^2C1C2) Is that what you mean?
The real component of this impedance is R = - gm/(ω^2C1C2)
the imaginary component is X = 1/sC1 + 1/sC2 which you could rewrite as
(C1+C2)/sC1C2
And also this is a small signal analysis, where gm does not vary. Maybe C1/C2 affects the bias point of the transistor? I am not familiar with that.
    GGAPBE96
colpitts negative resistance
No,I'm focusing on the real part.
As you said,C1/C2 may change the transistor condition..
I might mistake the premise.
Maybe I ought to consider the open loop gain.
The equation "R = -gm/(ω^2C1C2)" is just derived from the circuit impedance.
The feedback is not considered..
what does negative resistance mean
May I jump into the discussion again ?
Here is a general remark: Each oscillator circuit can be viewed as a negative resistance type or as a 4-pole type (gain stage with feedback). It depends which sight you prefer resp. which approach is more suitable.
Therefore: If you decide to handle the colpitt oscillator from the negative resistance viewpoint (which sounds reasonable) you must not consider any feedback again (that means: the second time). The circuitry with the negative input resistance is shunted with a lossy inductance. That´s all !
And from the CLAPP oscillator which I have analyzed already (and which is very similar to COLPITT) I know that it has the same neg. input resistance as mentioned above, that is: Zin= 1/sC1 + 1/sC2 - gm/(ω^2C1C2)
    GGAPBE96
explanation of a resistance equation
Thank you for the detailed comment!
I didn't know an oscillator can be defined as 2 different viewpoints.
I simulated the negative resistance of some oscillators,
and the results showed the negative resistance was proportional to C2/C1.
So,I doubted the equation was not accurate.
I'll study the basics of oscillators again.
