I am working on a project and i have no idea on pic programming. My project is to interface PIC16F877A with LM35 and when it gets body temperature between 37.5 Celsius to 40.0 Celsius, the led red light and buzzer should turn ON.
If the body temperature is between 36.8 Celsius to 37.5 Celsius, the led green turn on and it will check temperature every 15 minutes once....
Can anyone one help to understanding me the code for PIC.
It would be good for you to divide your work in modules. LM 35 is analog sensor, it will give output in volts which is very low. So you need to amplify voltage before feeding it to microcontroller. Develop other modules from PIC controller side, like Buzzer, led on-off, timer and ADC individually. Integrate all after that. Hope this helps.
Guys thanks for the reply...but im still blur in the code because i have no experience using embedded system using micro controller (PIC16F877A) with LM35....
