NEEDED A 24 HOUR TIMER
sudhir258
Junior Member level 2
I NEEDED A 24 HOUR TIMER BECAUSE I HAVE A WATER MOTOR WHICH I SWITCH "ON" EVERYDAY AT 6.00 AM TO 6.30 AM SO I WANTED A 24 HOUR MICRO CONTROLLER TIMER.
I HAVE ALSO SEEN IN THE SILICON CHIP MAGAZINE ISSUE OCTOBER 2006.
Hi Sudhir258, here´s the Silicon Chip issue, i hope it helps you.
    sudhir258
THANKS FOR THE SILICON CHIP BUT HOW DO WE PROGRAM THE PC697 TIMER
simple one
or build it using a pic microcontroller
COULD ANYONE PLEASE GET ME A PIC MICROCONTROLLER 24 HOUR TIMER
Do you know how to program a PIC?
Do you know how to write code in assembly?
Then download the book
There is one clock circuit and detailed asm file of the clock. assamble the clock and I will help you to modify the asm file to work as a timer of 24 hour or 364 day timer!!!
good luck
