Sep 9, 2006 #1 mtkee2003 Full Member level 2 Joined Sep 24, 2005 Messages 132 Helped 4 Reputation 10 Reaction score 1 Trophy points 1,298 Activity points 2,356 hi! The MAX5352 is a 12-bit digital to analog converter which uses a 3-wire serial interface. it has a built-in opamp follower. also it doesn't have an internal reference voltage. it has a 16-bit control word. here you can download its datasheet: https://pdf1.alldatasheet.com/datasheet-pdf/view/73531/MAXIM/MAX5352.html please introduce other ICs that is very similar to MAX5352. regards, Mostafa
