Need help with using Xilinx EDK
r_p_sanna
Member level 3
Xilinx EDK
can someone help me out with using a embedded development kit(EDK) ? I want to add an existing HDL design and a embedded software to a virtex-II pro device. Please help me out.
EDALIST
Full Member level 2
Re: Xilinx EDK
there are several ways :
the 2 main aproaches are :
1. the edk will be sub -model in your ise design => easiest, p@r is done in ise.
2. the hdl will be inside your edk design as ip core => complicated, but more open for s/w integration.
r_p_sanna
Member level 3
Re: Xilinx EDK
I'm trying to use powerpc in my system using EDK. there are a lot of options using the XPS. all i need is to interface it with my hardware. how do i go about to produce the minimum pin list ? also, is there something like a powerpc block diagram somewhere with pin list included? Will be very grateful for your help.
Thank you.
