pkchen
Newbie level 2
I'm getting some 'did not converge' error messages. How do I solve this problem? My sweep is already set at the maximum 10,000 data points. I think I might not have setup the ports/excitations or boundaries correctly.
The inductor has 2 layers; the 3rd layer at the bottom is the ground plane. The rectangle that you see is the port. Right now I'm drawing the terminal line from the top of the ground plane to to bottom of the middle layer, is this correct? What do I set for the boundary conditions?
I've attached a file so you can see what I've said. I've kept it under 250k so I think it shouldn't take any points (not sure what this is, I'm new).
(I accidently posted this in the RF forum; I deleted it from there and reposted here.)
