need help with a part of my project
Spectre90
Newbie level 6
ok this might be confusing but bare with me....
im trying to make 12-bit stop counter where i have one button input that stop each 4-bits slots i'll put in my segment display module
whenever i press a button, it stops one segment to display a number and if i press the same button again, displays a number on the other display with the 1st still on, then same with the third display; the last display will be fixed values.
i made a block diagram to explain it better.
i need some idea to make this module
should i go with making 3 different module with an enable or state (or case) statement to implement
i hope the drawing helps
You need:
1. a debounce circuit on the Btn_in
2. a FSM to control which of the 3 counters you want to stop.
3. Now the spec gets fuzzy.
What is the counter supposed to do? Does it count binary from 0-(2^12-1) and you just extract the bits as [3:0], [7:4], and [11:8]? Do the counter bits for the upper nibbles count as if the lower nibbles were still counting, or do they count at the lower nibble count rate?
If you need to count always as if the 12-bit counter was always running and you are capturing the nibbles, then you should have:
3a. 12-bit counter
3b. 3 4-bit capture registers, to hold the nibble for each 7seg while you wait for next button press.
4. some way to reset the 7seg to try again.
It's more like 3x4-bit capture register
And it counts a binary 1 to 9 (4-bit loop). And it goes to the [11:8],[7:4] and [3:0] input of my 7 seg module. The [15:12] will be fixed values.
And yes there will be a reset register ... Or button to start back from the 1st segment slot
mentioned that in 3b.
so does this mean each nibble (4-bit) counts at whatever clock you use? i.e. has no relationship to the other nibble counters.
don't forget to debounce that input too, if you use a button, and a synchronizer if the reset register is asynchronous to the counter.
