Need help in Verilog hdl universal shift register test bench
Shakir Ullah
Newbie level 3
Newbie level 3
please help ma regarding the test bench of the following code. I have tried it but it is not working.
Code Verilog - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
module ShiftRegister8(
input sl, sr, clk,
input [7:0] ParIn,
input [1:0] m,
output reg [7:0] ParOut);
always @(negedge clk) begin
case (m)
0: ParOut <= ParOut;
1: ParOut <= {sl, ParOut [7:1]};
2: ParOut <= {ParOut [6:0], sr};
3: ParOut <= ParIn;
default: ParOut <= 8'bX;
endcase
end
endmodule
// Test bench that i have tried but not working
module TB_ShiftRegister8();
reg sl, sr, clk;
reg [7:0] ParIn;
reg [1:0] m;
wire [7:0] ParOut;
initial
$monitor ("SL: %b , SR: %b , PARIN: %b , M: %b , PAROUT: %b ", sl, sr, ParIn, m, ParOut);
initial
begin
#10 sl = 1; ParIn = 8'b1; m = 0;
#10 sr = 1; ParIn = 8'b1; m = 1;
#10 sl = 1; ParIn = 8'b1; m = 2;
#10 sl = 1; sr = 1; ParIn = 8'b1; m = 3;
#10 $stop;
end
ShiftRegister8 M0 (sl, sr, clk, ParIn, m, ParOut);
endmodule
You dont generate the clock in your testbench
How can i do it i am new in verilog please help
8
9
10
11
12
reg clk;
initial begin
  clk = 0;
  forever #5 clk = ~clk;
end
// or ...
reg clk;
initial begin
  clk = 0;
end
always #5 clk = ~clk;
Now i am getting this Output
# SL: x , SR: x , PARIN: xxxxxxxx , M: xx , PAROUT: xxxxxxxx
# SL: 0 , SR: 0 , PARIN: 00000001 , M: 00 , PAROUT: xxxxxxxx
# SL: 1 , SR: 0 , PARIN: 00000001 , M: 01 , PAROUT: 1xxxxxxx
# SL: 0 , SR: 1 , PARIN: 00000001 , M: 10 , PAROUT: xxxxxxx1
# SL: 1 , SR: 1 , PARIN: 00000001 , M: 11 , PAROUT: 00000001
You didn't originally apply any of the inputs based on a clock so your output is going to match whatever you stimulate the design with.
So your output is correct based on your testbench. If you want it to shift more then you'll have to make sure the signals don't change until you've done all the required shifts.
You should probably at least read some tutorial on testbenches. e.g. https://www.asic-world.com/verilog/art_testbench_writing.html
