ghostridergr
Member level 1
Well as this is my first synthesis, I need your help so as to realize certain things and be able to continue my project. I am using a Virtex6 , and my ISE is that ot Xilinx.
My code is this:
and after many changes the remaining warnings and info are those:
1)
Info
What are these? Does it mean that the synthesizer doesn't understanfd my array as RAM? If this is so, is there any standard model for the synthesizer to understand my component as a RAM?
2)
Warnings:
and I get the same one for min_16 to min_23, k_5 to k_8 signals and so on. Is this because with the constant chosens these bits tend to always be 0? If this is, its now worrying becauce I used these numbers just to test it, it will not be like that in my final code.
3) I am getting also this warning several times.
What is this?
My code is this:
library IEEE;
use IEEE.std_logic_1164.all;
use STD.TEXTIO.all;
use IEEE.std_logic_unsigned.all;
use IEEE.std_logic_arith.all;
use work.my_package.all;
entity landmark is
generic
(N :integer := 8;
NA:integer:=2 );
port ( clk:in std_logic;
new_set: in std_logic;
vin:in std_logic;
rst:in std_logic;
din: in signed(N-1 downto 0);
dout: out big_matrix(0 to 3);
done: out std_logic
end landmark;
architecture TB_ARCHITECTURE of landmark is
signal inp1,inp2: matrix1_t(0 to NA);
signal flag:std_logic:='0';
signal k:integer range 0 to 100:= 0;
signal l:integer range 0 to 100:= 0;
signal i:integer range 0 to 100:= 0;
signal j:integer range 0 to 100:= 0;
function sum_of_square_dif( a1,b1: in signed(N-1 downto 0); previous_sum:in std_logic_vector(3*N-1 downto 0))return std_logic_vector is
variable temp_sum:std_logic_vector(3*N-1 downto 0):=(others=>'0');
variable diff: signed(N-1 downto 0):=(others=>'0');
variable square_diff: std_logic_vector(2*N-1 downto 0):=(others=>'0');
begin
temp_sum:=previous_sum;
diff:=a1-b1;
square_diff:=ext(diff*diff,2*N);
temp_sum:=ext(temp_sum+square_diff,3*N);
return temp_sum;
end sum_of_square_dif;
function find_min(row: in big_matrix(0 to NA)) return signed is
variable temp_min:signed(3*N-1 downto 0);
begin
temp_min:=row(0);
checking: for t in 1 to 3 loop
if (row(t)<temp_min) then
temp_min:=row(t);
end if;
end loop checking;
return temp_min;
end find_min;
begin
process (clk,rst)
variable ii,jj,kk:integer:=0;
begin
if (rst='1') then
jj:=0;
ii:=0;
--mhdenise mnhmh
elsif (clk'event and clk='0') then --diavasma sthn arnhtikh akmh
if (vin='1') then --vin enable signal
--main body
if (new_set='0') then --gemisma prwtou pinaka
ii:=i;
if (ii<=NA) then
inp1(ii)<=din;
i<=i+1;
end if;
else --gemisma defterou pinaka
jj:=j;
if (jj<=NA) then
inp2(jj)<=din;
j<=j+1;
end if;
end if;
if ((j>=NA)and(i>=NA)) then
flag<='1';
end if;
end if;
end if;
end process;
process(clk)
variable row:integer;
variable column: integer;
variable line_finished: std_logic;
variable temp,min:signed(23 downto 0);
begin
--row:=k;
--column:=l;
if (clk'event and clk='1') then
if (flag='1') then
if (k<=NA) then
if(l<NA) then
line_finished:='0';
if(l=1) then
min:=signed(ext(sum_of_square_dif(inp1(k),inp2(l),"000000000000000000000000"),3*N));
-- dout(k)<=min;
else
temp:=signed(ext(sum_of_square_dif(inp1(k),inp2(l),"000000000000000000000000"),3*N));
if (temp < min) then
min:=temp;
else
min:=min;
end if;
end if;
l<=l+1;
else --l=3
line_finished:='1';
l<=0;
k<=k+1;
dout(k)<=min;
end if;
else
line_finished:='Z'; --value that does nothing
end if;
end if;
end if;
end process;
end TB_ARCHITECTURE;
1)
Info
Xst:3218 - HDL ADVISOR - The RAM <Mram_inp1> will be implemented on LUTs either because you have described an asynchronous read or because of currently unsupported block RAM features. If you have described an asynchronous read, making it synchronous would allow you to take advantage of available block RAM resources, for optimized device usage and improved timings. Please refer to your documentation for coding guidelines.
Xst:3218 - HDL ADVISOR - The RAM <Mram_inp2> will be implemented on LUTs either because you have described an asynchronous read or because of currently unsupported block RAM features. If you have described an asynchronous read, making it synchronous would allow you to take advantage of available block RAM resources, for optimized device usage and improved timings. Please refer to your documentation for coding guidelines.
Xst:3218 - HDL ADVISOR - The RAM <Mram_inp21> will be implemented on LUTs either because you have described an asynchronous read or because of currently unsupported block RAM features. If you have described an asynchronous read, making it synchronous would allow you to take advantage of available block RAM resources, for optimized device usage and improved timings. Please refer to your documentation for coding guidelines.
2)
Warnings:
Xst:1710 - FF/Latch <min_16> (without init value) has a constant value of 0 in block <landmark>. This FF/Latch will be trimmed during the optimization process.
PhysDesignRules:372 - Gated clock. Clock net n0039 is sourced by a combinatorial pin. This is not good design practice. Use the CE pin to control the loading of data into the flip-flop. New
WARNING PhysDesignRules:372 - Gated clock. Clock net flag_k[6]_AND_99_o is sourced by a combinatorial pin. This is not good design practice. Use the CE pin to control the loading of data into the flip-flop. New
WARNING PhysDesignRules:372 - Gated clock. Clock net flag_k[6]_AND_545_o is sourced by a combinatorial pin. This is not good design practice. Use the CE pin to control the loading of data into the flip-flop. New
WARNING PhysDesignRules:372 - Gated clock. Clock net flag_k[6]_AND_641_o is sourced by a combinatorial pin. This is not good design practice. Use the CE pin to control the loading of data into the flip-flop. New
WARNING PhysDesignRules:372 - Gated clock. Clock net flag_k[6]_AND_449_o is sourced by a combinatorial pin. This is not good design practice. Use the CE pin to control the loading of data into the flip-flop. New
WARNING PhysDesignRules:372 - Gated clock. Clock net flag_k[6]_AND_737_o is sourced by a combinatorial pin. This is not good design practice. Use the CE pin to control the loading of data into the flip-flop. New
WARNING PhysDesignRules:372 - Gated clock. Clock net flag_k[6]_AND_833_o is sourced by a combinatorial pin. This is not good design practice. Use the CE pin to control the loading of data into the flip-flop. New
WARNING PhysDesignRules:372 - Gated clock. Clock net flag_k[6]_AND_593_o is sourced by a combinatorial pin. This is not good design practice. Use the CE pin to control the loading of data into the flip-flop.
and so on
What is this?
