kasthu
Newbie level 3
me newly working in textio function. integer files to write and read no problem,where as to write the output of binary vectors problem. any one know syntax for that help me please.below is code.
1)library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use std.textio.all;
entity m is
Port ( clk ,rst: in STD_LOGIC);
end m;
architecture Behavioral of m is
begin
process(clk,rst)
file outfile:text is out"d:\kasthu\outfile1.txt";
variable outline:line;
variable q:bit_vector(4 downto 0);
begin
if(rst='1')then
q:="00000";
elsif(clk'event and clk='1')then
q:=q+1;
write(outline,q);
writeline(outfile,outline);
end if;
end process;
end Behavioral;
error:
+ can not have such operands in this context.
2)library IEEE;
use std.textio.all;
entity lf is
Port ( clk,rst : in STD_LOGIC;
q :inout STD_LOGIC_vector(4 downto 0));
end lf;
architecture Behavioral of lf is
begin
process(clk,rst)
file outfile:text is out"d:\kas\outfile1.txt";
begin
for i in 0 to 31 loop
if(rst='1')then
q<="00001";
q(0)<=q(4) ;
q(1)<=q(0);
q(2)<=q(1);
q(3)<=q(2);
q(4)<=q(3);
write(outline,q);
end if;
end loop;
end process;
end Behavioral;
error:
write can not have such operands in this context.
1)library IEEE;
use std.textio.all;
entity m is
end m;
begin
process(clk,rst)
begin
if(rst='1')then
q:="00000";
q:=q+1;
write(outline,q);
end if;
end process;
end Behavioral;
error:
2)library IEEE;
use std.textio.all;
entity lf is
end lf;
begin
process(clk,rst)
begin
if(rst='1')then
q<="00001";
q(0)<=q(4) ;
q(1)<=q(0);
q(2)<=q(1);
q(3)<=q(2);
q(4)<=q(3);
write(outline,q);
end if;
end loop;
end process;
end Behavioral;
error:
