Hi Ferdows,
Thanks for the reply. I didn't simulate based on paper, its on top of PCB (substrate). Why is there anything wrong? And I like to know what is the copper thickness to use, I used 0.035mm seems to be a bit thick?
Once again thanks for the help!
---------- Post added at 02:38 ---------- Previous post was at 02:32 ----------
Hi Rotmanlens,
Thanks for the reply, and I know my antenna is not radiating at the desired frequency. Currently I am using copper thickness of 0.035mm , is that ok if I change it to 0.0005mm, or what do you recommend?
And also like to know if, you change the sweep frequency, for what I have done is, I simulated from 100MHz to 3GHz, then I get results for S11 and then I changed the from 100MHz to 10GHz then I get another results of S11, both the results has some a little different values for S11, is that normal or is abnormal...did you experience the same problem?
Thanks again....
Manimaran
