need debugging attached hfss design
THUNDERRr
Full Member level 3
please
anyone help me debugging this
i simulate 9 conductors surronded by sio2 (insulators) and all in a si substrate
i try to get the z,y paramters they are always zero why?
toonafishy
Full Member level 6
Earth
your wave ports are the same diameter as the copper cylinder (25um), normally you want wave ports larger than the conductor they are illuminating
THUNDERRr
Full Member level 3
why? could u please modify it and supply the file again?
Added after 1 minutes:
i mean if i make the waveport larger than the copper it will intersect with the silicon dioxide surrounding copper is it ok?
toonafishy
Full Member level 6
Earth
i found the problem - you have assigned bulk conductivity to the silicon and silicon dioxide. remove this and the simulation works. i have not been able to use conductivity in a dielectric and wave ports together. in those cases, i use lumped ports and terminal mode solution.
in general, wave ports should be much larger than the conductor they are illuminating. they should cover the conductor and a large portion of the dielectric. otherwise the results will not be accurate. you can see this in the HFSS manual example 6.5.
