Need Data Sheet For Motorola M952 Transistor
radiotek
Junior Member level 2
I am working on a old RF Generator and I now need a part but I can not dind any specs for it. T he part has the following on it: 0142 and below that it says M952
Any idea of what it could be replaced with ? Appreciate any help.
It certainly looks like a Motorola device and the 952 is probably a date code, I would guess 1989 week 52 but I can't trace any reference to 0142 around that date or later so it could be house coded instead of having a generic number.
What is the model of the RF Generator? It may be easier to trace the manual for it and work backwards to trace the part or a replacement.
Brian.
Search Results
2N592 NOS Transistor
Ampex - JEDEC Transistor Cross Reference
2N592 Ampex Transistor Cross Reference 014-214
transistors_2N
2N592 Ge pnp 125mW 20V - 20V 200mA 85>C 100KHz - 20MIN GIC TO5 Low Power General Purpose
Possible Substitutes
AC125 2N406 MP20A
NTE100 (PNP) Germanium
http://www.nteinc.com/specs/100to199/pdf/nte100.pdf
Material of 2N592 transistor: Ge
Structure of 2N592 transistor: pnp
Maximum collector power dissipation of 2N592 transistor (Pc): 125mW
Maximum collector-base voltage of 2N592 transistor (Ucb): 20V
Maximum collector-emitter voltage of 2N592 transistor (Uce): -
Maximum emitter-base voltage of 2N592 transistor (Ueb): 20V
Maximum collector current of 2N592 transistor (Ic max): 200mA
Maximum junction temperature of 2N592 transistor (Tj): 85�C
Transition frequency of 2N592 transistor (ft): 100KHz
Collector capacitance of 2N592 transistor (Cc), Pf: -
Forward current transfer ratio of 2N592 transistor (hFE), min/max: 20MIN
Manufacturer of 2N592 transistor: GI
Case of 2N592 transistor: TO5
Application of 2N592 transistor: Low Power, General Purpose
Check with OnSemi. That portfolio of products was spun off back in the 90s.
