need c code sdcc for lcd2*16 and microcontrollor16f877a
dzaea
hi every body,
i need c code sdcc for lcd2*16 and µcontrollor pic 16f877a to try it in my µcontrollor .
and i have other question if the code run in simulation in proteus is it mean that the code run in realty?
Any LCD code written except mikroC LCD code will work fine with SDCC Compiler. Google for 8-bit and 4-bit LCD code. You can find it at saeedsolutions.blogspot.com
If the delays are proper then it will work in both Proteus and hardware.
Are you using SDCC Compiler with eclipse Juno. If yes, can you post the sh.exe file. I have problem with my sh.exe file. When I try to Compile code using SDCC and eclipse it crashes. Zip and post both sh.exe and sh08.exe files.
Reactions: dzaea
    dzaea
No, i'm using the piklab ide.
